Results 1 to 3 of 3
  1. #1
    Default 1979 Johnson 70 hp compression
    What would be good compression numbers on a 1979 Johnson 70 hp.
  2. #2
    Default Re: 1979 Johnson 70 hp compression
    I have not checked the compression yet, it is a motor I am considering buying, I will be checking compression cold at WOT. My 4cyl Mercs all have about 120 lbs compression. I understand the 10% high low, but what is a good number for the Johnson ?
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    12,646
    The last 2 Johnson 3 cylinder motors I checked showed 150 PSI on a new gauge.
Similar Threads
  1. compression test in 1979 350 Chevy/Volvo
    By Rainbow Bridge in forum Volvo Penta Gas Engine Forum
    Last Post: 05-12-2011, 12:19 PM
  2. 1979 MerCruiser 260 compression
    By TomB985 in forum Mercruiser Sterndrive Forum
    Last Post: 03-25-2011, 06:41 PM
  3. Compression test on a 1979 9.9?
    By jim18611865 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-26-2010, 05:17 PM
  4. Compression on Mercruiser 1979 120
    By roadpacker in forum Mercruiser Sterndrive Forum
    Last Post: 07-20-2010, 06:27 AM
  5. 1979 Johnson 55 hp model 55E compression spec
    By pandrew6l in forum Johnson Evinrude Outboard Archive
    Last Post: 07-21-2006, 12:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
