I replaced the head, camshaft and waterpump on my 1977 140hp mercruiser(gm block). I am not very mechanical so this has been a challenge. After putting everything together I took it to an auto mechanic to adjust the distributor and set timing. They could not get the boat to idle below 2000 rpms. They told me that either a carburator issues or exhaust leak could cause this. I did not have this issue when the head rusted through last fall.
When I started it up in the driveway I noticed a steady whisp of smoke coming from where the throttle linkage connects to the exhaust manifold. I am thinking this is not good. The bolt hole seems to be roughly 1.5-2 inches deep. I am thinking I should attempt to JB weld the back of the whole and then coat the bolt with gasket sealant when I reinstall the linkage.
Any advice would be greatly appreciated.
Greg
Greg
