Please help with a solution to the following. My boat often sits idle in the lake for 2, 3, 4 weeks at a time. When going to start it, and following the directions that I was told by the mechanic, this motor often takes 20-30 minutes or longer of starting attempts before it runs. The choke is working, I've tried with and without pumping the gas primer, Gas is fresh and have even used stabil.
Once running I can stop and start all day long without issues, but once I let it sit and return a few weeks later it will not fire up as it should.
