1997 johnson 150 vro 60 degree.replaced fuel pump ,was pumping too much oil, purchased from your company. motor ran great about month. now gas is squrting out top left bank carb vent and in carb throat only when running removed and replaced float level ,needle & seat and all that stuff did not need it all was good condition did it anyway.switched the lower carb to the top* to make sure it wasen't the carb,did the same with that carb* squeeze the bulb gets hard no gas squirting out carb it appears to have too much fuel pressure.where do i look now.i'm retired mechanic this is the one thing i don't want to be working on my boat .i want to go fishing
