I just put in a reman long block and it is running hot. It is a 1984, Crusader 270 (GM 350 block). Freshwater cooled. It runs around 160 at an idle, with or without the thermostat in. (It is now out) The faster you go, the hotter it gets, but it takes a couple of minutes to get up to around 200, at which point I throttle back, so I don't know how bad it will get. I replaced the impeller. One exhaust manifold was sometimes hotter than the other, so I replaced it. No difference. Raw water flows. Raw water filter is clean. Antifreeze flows back to the heat exchanger from both manifolds. (so I know both pumps are working and fluid is circulating everywhere it should) I have flushed everything I can and as far as I can tell both systems flow freely without obstruction.
I don't know what else to check or replace. Any suggestions? Does anyone know what the flow rate for the two systems should be? Is there anyway to pin down the source of the problem by measuring the temperature at various places, e.g. either fluid going in/out of heat exchanger?
I thought it might be the "new" block, but if there was some blockage in it that prevents enough flow at high temperature it doesn't make sense that not enough would flow through at idle to keep it cool then. Right?
In short, all components of the cooling system seem to be fine, it is just not quite pulling away enough heat from the engine.
I would appreciate any suggestions. Going everywhere at 6kts is getting to me.
