Allways disconnect the battery and never apply power to the two Magneto wires they are for the kill circuit only if you short them to bat pos you will be changing a coil or two. Six terminal is push to choke you can use the old choke switch for a horn or something. Just make sure everything is wired correct double checked before you connect the battery.
