SOAPSTONEARTIST
I had asked a question earlier this year about my overheating problem. I got a water pump repair kit and installed it. UNFORTUNATELY FOR ME, when I re-assembled the lower unit, I "missed" putting the water pipe into the rubber grommet on top of the water pump. I drove my boat for about 3-4 minutes and shut it down when I noticed there was no pee stream. By that time I think it was too late. One cylinder got very hot and even melted the small plastic connectors for the rubber hoses, the heat gauge and the thermostat. There wasn't any fire but there was smoke from the melted plastics. I let it cool down for an hour and then tried it again. It started right up so I thought I was lucky and didn't seize a piston. I had to wait for the low tide to get at and change/fix the water pipe connection, and then when it was high tide again I tried it. It turned over but was very had to turn over even with a battery charger connected. I don't have a clue what to do now.
I'm "guessing" that I may have seized a piston ring but I need some help here.
Many thanks in advance to the guys who give me advice on here. I really appreciate it
