Change from transom mount to bow mount.
wassajet
Hi, is there any way i can turn the tiller steer on my Minn kota 50 lb thrust around 180 deg. so that i can convert it from a transom mount to a bow mount? In other words the tiller handle will be facing the same way as the propeller.
Yes. Remove the bolt from under the control head assembly and turn the head around. Just make sure you don't pinch the wires when you reinstall the bolt.
