Sean McDaniel
Hi guys,
I am new to the forum, but need some advice. I want to replace the fuel lines inside the cowling with something that is more resistant to this crappy alcohol laden fuel. I have started running ethanol free fuel, but I still have issues with this hose breaking down. It had welded itself to the carb nipple when I recently pulled the carb off to clean out a clogged idle jet. I suspect a bit of this hose is what is causing my clogging. Any recommendations? This is the A2 model if it matters.
Sean
Sean
