The thermostat serves to regulate a constant temperature throughout the powerhead. It also provides a needed restrictor to cause the water jacket to fill completely with water, thereby circulating cooling water to the entire powerhead. The top area being most critical because it absorbs the most heat from the cylinder(s) in every motor. Without the thermostat there is NO restriction to water flow through the powerhead and the cooling water of course takes the path of least resistance and just flows unrestricted out the water exits without completely filling the powerhead water jacket. The top of the powerhead receives less cooling water and develops hot spots and early metal fatigue related failures. It doesn't hurt to run the motor for a short time without it just to check if this will cure the lack of a tell-tale stream but I would be very surprised if it does. If you found the old thermostat severely corroded there is a good chance that the interior walls of the cooling jacket are also corroded and the nipple to the tell-tale outlet is blocked with this corrosion or some other object. With the thermostat out you should be able to blow air into the tell-tale outlet and hear or feel it being passed through with the thermostat cover off. If not you're going to need to run some stainless wire or similar up into that tubing till it clears the obstacle out. If you see a lot of corrosion in the water jacket you can spray some CLR into the water jacket and let it clean it out, then flush it thoroughly with water.
HI....I see you haven't been on here in a long time but I ran across your reply to the OP and it's of great help. I'm trying to get water out of the bleedhole and something inside that water jacket must be clogged. With the motor running, I have water coming out of the thermostat area when it's removed, so I know the impeller is working. I also know that the bleedhole tube and the tube forming a U on the bottom of the water jacket is free and clear. Something inside that water jacket must be completely blocking the flow as when I try to shoot air through one of the tube ends, it just blows the tube off the nipple. Even shooting air straight into the nipple builds up pressure and essentially blows the air nozzle off. No air comes out of the thermostat area like you suggest. What would you recommend? Can that water jacket be disassembled? And do I shoot that CLR into those nipples on the water jacket? I don't know how it would penetrate into it but perhaps that'll work?
Thanks in advance if you get this message!!!
-Mike
