Hi Guys
I am really hoping someone can help me, I recently upgraded to a Force 120hp motor and have been having problems getting it going properly. When I run it out of the water on muffs it runs lovely, as soon as I put it in the water it does start but cuts of after a few seconds. It will only stay running on the water if the cowl is removed. Now this baffled the hell out of me for some time and after a few pain staking trips to the water (40 minutes away) and not being able to get it to work i took it to a local repair place who diagnosed that it was an exhaust problem and that the exhaust fumes where not coming out of the exhaust and prop as they should but coming up in the motor and so choking the carbs causing it to cut out. they also said I have a worn or missing seal in the exhaust which was causing the problem. After alot of investigating I have found the seal that I should have which is not on my motor(thanks to the lovely chap who sold it to me!)My question is this is this correct? and if so does anyone have any idea where I can get one of these seals? The link below shows the seal it is item 93 on the top right corner of the diagram.
http://www.boats.net/parts/search/M...992 L-DRIVE)/120LD92B/GEAR HOUSING/parts.html
Any input will be most appreciated guys
