Hi all,
I recently aquired a 1973 Arrow Glass Tigre I/O powered by a Chevy 250 inline 6 with an OMC 165hp sterndrive. Here is some history: After a couple hours of tubing on the lake, the shift lever was put into forward position followed by a loud electrical sounding pop noise from the stern of the boat. After that popping noise there has been no forward or reverse. The engine starts and runs great but the prop would not engage. The boat was towed off the lake. A mechanic at one local shop seemed to think they should be more worried about wether or not the supposed short caused reverse and forward to try and egage at the same time. Therefore, the previous owner took the lower unit off the sterndrive in an attempt to look for broken bits and pieces but did not get very far after seperating the units. Now the boat is mine and I'm staring at the trailered boat and a box of lower sterndrive parts wondering where to begin.
It has not been started since the lower unit was removed. It does have the adaptor plate for a garden hose to be attached to the upper unit. I know very little about these systems but I tend to be handy with a wrench and I managed to find a Clymers manual at one local boatshop. I would appreciate any advice before I jump in too far over my head. If I can solve this drive/electrical problem I intend to give the boat a nice cosmetic restore.
For starters, I suspect the switch/lever may have gone bad and based on a few other posts I have seen on this forum, wiring a solid three way (on-off-on) switch may be a viable replacement for that. However, what may have caused that loud 'pop'? I was told it sounded decidely electrical. All of the fuses, that I have been able to find, appear good. I do not see anything obviously cooked, melted or smell anything obviously burnt in the engine compartment. Should I suspect any particular solenoid(s) and where might they be located? Should I attempt to pull the lower unit completely apart and have a look at the forward and reverse springs/clutches? I am not gleaning the answers I had hoped to find within this Clymer's. Or maybe I just haven't yet connected the dots, lol.
Here's hoping for something relatively simple...
Thanks,
-Hawger
Thanks,
-Hawger
