Hi Westford.
I done it all in situ was no need to remove.
I removed the pulley off of the water pump to expose the end of the heat exchanger easily (the oil cooler is also on the end of the heat exchanger so is gets cleaned aswell), dropped the anode out and removed the end plate of the heat exchanger. Poked out the heat exchanger with a metal rod best I could and then refitted the end cap upside down so anode hole now facing upwards(note you can only fit 2 of the 4 bolts in)
I then removed the anode from the intercooler and then removed the end plate of the intercooler And again cleared it best I could with a metal rod and again put the end cap back on upside down with anode hole facing upwards.
I then filled the intercooler and heat exchanger up with hydrochloride acid (aka brick/patio cleaner) and screwed in the anodes while the acid done its stuff, foams and fizzes, dissolves all the salt and scale without damaging anything else. Once the acid had finished, removed both end caps exposing the now immaculate heat exchangers, refit end caps, pulleys, anodes etc and then run engine to flush through, repeated on other engine and sea trial.
Mine now absolutely perfect at full revs 3700 temp stays at constant 85.
Hope this helps.
Ian
