Another problem with my 440s....For no apparent reason or oncoming symptoms, my port engine would not even turn over. Once the key was turned, it was if I was trying to start it when in gear. As you know, you will not get a response. I opened up the electronic ignition plastic cover, nothing jumped out at me and indicated a problem, so I lightly tapped on things with the end of my screwdriver. Whatever I did, it worked. I have now had this problem when engine was cold and now again, when hot. However, when I tapped on those items when the engine was hot, I did not get a response. The engine just decided to start for me.
What do you think?
What do you think?
