1993 Johnson 48 spl tilt and trim retainer plug removal.
rivins
looking at the trim and tilt from the rear the large plug at the bottom. I am having a tough time getting this plug out its leaking from the plug
It is part #0335138 on the parts look up.
Model # j48eslete under accesories tilt and trim. Thank You.
That plug may be quite a pain to get out. In most cases I had to VERY carefully drill it out. Most likely due to corrosion. After replacing, change location of the zink to a lower position as it is probably not submerged in water and the plug is the one suffering instead.
