I have a really nice 1990 Mainship 36 Express that I am constantly having to keep my cooling system at perfectly maintained levels during the summer just to keep both engine's temperatures at bay. The problem? Nothing with the boat I believe. Ok, well yeah one engine is more touchy than the other but both HE's are completely clean, both impellers perfect, both U-coolers flow freely, new risers, etc.. Every summer I have the same deal.. Always wants to break out past 175 unless everything is perfectly perfect. The one engine that isn't touchy, even if that behaves, it still has to play catch up after coming down off plane to get rid of that heat. Why?
I'll tell you why! The water temp in freakin Tampa Bay is 92 degrees right now!!! That's right, 92! The other mitigating factor is that I'm running a FULL closed cooling system. The heat exchanger has to take on the load of cooling the exhaust manifolds as well as the block.. Plus I dock in Apollo Beach, right next to the power plant where it dumps hot water into the bay on top of the hot bay water leading into the hot gulf (close to 90 degrees in the Gulf!!)..
The only solution I see at this point is re plumb it as a half system and install an inboard flush kit. Sure, seawater will flow through the manifolds now but I'll flush it out at the end of the day so it's a good trade off.
The half system is a lot more efficient at the expense of wear and tear on manifolds but the HE will only have the load of cooling the block and from what I've read, most systems down here are half systems for this very reason. I wouldn't even be having this one way discussion if I lived on the Atlantic side of Florida.. It'd be fine. It'd be fine with some blockage even..
...I will be shocked if this doesn't fix my summer problem once and for all..
Or, I could wait until September when the temperature drops 5 degrees.. Literally, that's all it takes.. When the incoming water is this hot, I just have no margin whatsoever....
Thoughts? Comments?
-Randy
Thoughts? Comments?
-Randy
