Hi there -
Hoping someone can offer some advice here - but this is our situation...
We have a Tohatsu 2002, which has been stored over the winter. We got the boat out a few weeks back, cleaned filter, checked plugs etc - didn't think much needed doing. It idles fine, so put it in the water.
The problem that we have is that when it's put in gear and given revs, it coughs, splutters, and generally wants to cut out.
There are no kinks in the fuel line, it has fresh fuel - although reading around, it sounds like the Carb must be run dry after each run... it this simply a matter of disconnecting the fuel supply and running it until it cuts out? Could not running it dry cause these problems? what can be done to resolve it - carb cleaner perhaps?
Many thanks in advance for any help,
Cheers,
Mike.
Cheers,
Mike.
