Results 1 to 14 of 14
  1. #1
    Default Ted Williams 7.5 H.P. Outboard
    I just picked up a Ted Williams 7.5 H.P. Outboard Model NO 217.585911 at a garage sale that they said that it doesn’t work. Was wondering if anyone knows about where one could find a repair manual and or parts. Thanks in advance. SD
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: Ted Williams 7.5 H.P. Outboard
    www.certifiedpartscorp.com/vintage you have to call them
    or http://www.boatsportandtackle.com/servlet/StoreFront
    we also have a Eska outboard yahoo group with great resources and some friendly discussion
    http://groups.yahoo.com/group/eskaoutboards/
    you can also use Sears parts for part numbers but don't expect to find reasonable prices or complete supplies of parts
    http://www.searspartsdirect.com/part...t/index.action
  3. #3
    Join Date
    Jan 2008
    Location
    black creek , ga,
    Posts
    180
    I should have a pdf manual for it if you still need it I can email to you.
    Every day is a new day.....GO FISHIN
    Scott
  4. #4
    Hi, I am working on a 1977, ESKA 7.5 and can't figure out how to pull the flywheel. How do you keep the flywheel from spinning when loosening the top bolt? Everything I read says to use a flywheel puller and attach using the three threaded holes on top of the flywheel. Only problem is, I can't find the three holes on my flywheel...unless they are under the starter cup. In which case I can't get at them because I'm unable to remove the top bolt.
    Any advice would be great.
  5. #5
    Join Date
    Jan 2008
    Location
    black creek , ga,
    Posts
    180
    Take the nut off the top and get a block of wood to put over stud and wack with a hammer should pop off.
    Scott
  6. #6
    Quote Originally Posted by brim_buster View Post
    Hello.. I was wondering if you still had this Ted Williams manual still kicking around.. I have a 7.5 Ted Williams but having a hard time locating the manual. Would be very greatfull if you can send me a copy to my email. Thanks in advance. Vince
    [email protected]
  7. #7
    Hi brim_buster, by chance, do you still have that manual for the 7.5 Ted Williams motor?
  8. #8
    vinceisworking, did you get the manual?
  9. #9
    Hi, does anyone have an electronic copy of an owners manual for a 7.5 Ted Williams?
    my email is:
    [email protected]
    Thank you so much
  10. #10
    Quote Originally Posted by vinceisworking View Post
    [email protected]
    would also like to get a manual if i could [email protected] thank you
  11. #11
    I also have a Ted Williams 7.5HP outboard motor and looking for a service manual. Would appreciate it very much if someone would email me one [email protected] Thank you in advance.
  12. #12
    Hello i also just got one of these motors and am looking for a manual because i cant get this thing to run. Any chance i could get a copy of that pdf ?
    [email protected]
    any help would be appreciated.
  13. #13
    How do you keep the flywheel from spinning when loosening the top bolt? Everything I read says to use a flywheel puller and attach mega joker free using the three threaded holes on top of the flywheel. Only problem is, I can't find the three holes on my flywheel
  14. #14
    You need a strap wrench they are not to expensive. Do u have a copy of owners manual or service manual 7.5hp [email protected]
Similar Threads
  1. Ted Williams outboard
    By bholt4511 in forum Ted Williams Outboards
    Last Post: 08-15-2011, 03:44 PM
  2. 75 HP SearsTed Williams Outboard
    By tatro in forum Ted Williams Outboards
    Last Post: 06-01-2009, 06:21 PM
  3. Tecumsehted williams air cooled outboard
    By cougarco93 in forum Ted Williams Outboards
    Last Post: 05-11-2009, 06:49 PM
  4. 7 12 HP Ted Williams Outboard
    By bayoucitybomber in forum Ted Williams Outboards
    Last Post: 08-06-2008, 05:59 AM
  5. Ted Williams 45hp outboard
    By cornhusker_brute in forum Ted Williams Outboards
    Last Post: 07-17-2008, 11:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
