To tell the year,should be a sticker on the transom clamp.
If it's a Blue Force they started making the 40 in 1992
Post that info and someone will be able to tell the year.
Before you do anything do a compression/spark test.
That ok do the rest.
New carb,depending on the year it probably isin't available.
And you probably don't need it.
Set the carb yourself.
Take it off and clean it.
Then while it's off look at the reeds.Any cracked or broken,replace.
The air screw(screw on the front top).
Or the side(screw with spring)
Turn it in to the bottom GENTLY!!!
Then out 1 turn.
Then in the water motor warm,in gear.
Motor running,turn screw in till it coughs,bucks,misses or stalls.
Then out 1/2 turn.
