Remove the flywheel, and you will see it.
However you may roughly check if ok without removing.
Remove the spark plugs.
Turn the engine until top piston (Cyl #1) is at TDC. (Use a screw/caliper or whatever to determine).
Check that the TDC mark on flywheel aligns with the TDC mark on either the manual starter or the notch on the electric starter.
If it does, key is OK.
