Click for Bukh manuals!
Results 1 to 3 of 3
  1. #1
    Default I get widely varying readings
    I get widely varying readings off the dip stick depending on if the filler plug is in or out. Please could someone advise me of the correct method for measuring the quantity of the gearbox oil. Could someone also confirm that the correct quantity is 1.1 L. Thanks!
  2. #2
    harbin's Avatar
    harbin Guest
    Default "I change the gear box oil on
    "I change the gear box oil on my Bukh 20 using a 50 mL syringe with pvc tubing down the gear box dipstick tube. My gear box capacity is 350 mL, not 1.1 L (although my manual says 1.1 L). I read the level when the dipstick is screwed home and I take time to let the dipstick tube level equilibrate with the gearbox. I have seen reported that it is important to use standard SAE 30 oil, not a multigrade, as additives in multigrades may cause corrosion of bronze bearings. Someone else might be able to let us know whether this is true or a furphy."
  3. #3
    Join Date
    Nov 2008
    Location
    , Kent, Great Britain
    Posts
    3
    Default "Reference the use of an SAE 3
    "Reference the use of an SAE 30 engine oil in a gearbox. The gearbox on you Bukh is manufactured by ZF & incorparates synchromesh rings. If you use a multigrade oil, this includes a VI Improver(viscosity index improver) ZF suggest it will put a glaze on the synchrodes. Mono Grades oils (ie SAE 30) are not easily available, however you can
    purchase an SAE 30 Engine OIl from a lawn mower supplier, or if in the UK available from a B & Q store. I use an SAE 30 in my gearbox, however I know people who use a multigrade oil in Buk/ZF boxes with out problems, -- so far !!!
    Regards Roger Harvey
    Lubricants Spe******t, Castrol Oils"
Similar Threads
  1. trim/tilt wont display correct reading
    By apreville in forum Volvo Penta Gas Engine Forum
    Last Post: 07-07-2010, 08:00 PM
  2. BF100 Carburetor cleaning method
    By gajpurdy in forum Honda Outboard Forum
    Last Post: 02-21-2010, 11:14 PM
  3. 1996 115hp mariner no tach reading and voltmeter reading less the 12 volt
    By tolongatsea in forum Mercury Mariner Outboard Archive
    Last Post: 05-06-2007, 10:20 PM
  4. Oil in the stern drive is clear and at the correct level but
    By junieb247 in forum Volvo Penta Gas Archive
    Last Post: 08-22-2006, 04:47 PM
  5. Is there a method of changing lower unit oil
    By scumbuster in forum Archive 2003-2009
    Last Post: 07-14-2003, 10:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
