Results 1 to 8 of 8
  1. #1
    Default 115hp 1993 feels hotter on left side of motor than right
    Hello,
    Is it normal for one side of the power head to be hotter than the other? The left side of my 1993 115hp Johnson is a bit hotter than the right side.
    I can hold my finger on the right side, but the left side is almost to hot to touch. Would a melt stick help to determine anything?
    Thanks for your help.
    J115TLETS
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    12,870
    Default Re: 115hp 1993 feels hotter on left side of motor than right
    How hot is hot ???------------There is a thermostat and poppit valve for each bank.--------You may also want to look into these curious things called " water deflectors " actually rubber tubes.--Water does NOT flow thriough these tubes , but they guide water for proper cooling.-----------you need to remove cylinderhead to inspect them.-------If these deflectors are swollen / out of place they can block / restrict waterflow in the water jacket.
  3. #3
    I have never removed a cylinderhead before but will try anything once. A visual inspection of the motor does not show any difference between the the two sides. I was going to use a some temp melt crayons to try and see if it was running hot on the port side. I can keep my finger on the starboard side heads, they are warm. The port side is hot to the touch. Not burn you hot but uncomfortable. I see no indications that the head gasket is coming out or exposed on the port side.
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    12,870
    Use the temple sticks to determine running temperature.-----Not sure on your comment on " head gasket coming out or exposed on port side " -why that comment ?
  5. #5
    In my backyard Florida motor butchery, I have seen what I assume is the head gaskets being "squeezed" out the side of the head. This would normally appear on a motor with dead or dying cylinder. I kinda thought that it may have been an indication of that head getting to hot and forcing/melting the gasket, but who knows, Florida is where all the weird stuff happens!
    Any recomodations on grease/ gasket compound?
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    12,870
    A new factory head gasket would have on it ----" do not use sealer "-------- clearly marked.
  7. #7
    Thanks for all the help. I will pull the heads and see what is the problem. The grease/ gasket question was for assembly of lower unit bit I will post a new thread for that.
  8. #8
    Thanks again for all the help. The return of the afternoon rains shut down this days surgery but will get back to it soon.
Similar Threads
  1. stuffing box temps, one side 25 degrees hotter
    By bobct in forum Crusader Marine Engine Forum
    Last Post: 06-22-2010, 08:39 PM
  2. 318 one side hotter than other
    By idigitu88 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-29-2009, 07:13 PM
  3. PORT SIDE RISER HOTTER THAN STARBOARD SIDE
    By Capt. Harry in forum Mercruiser Sterndrive Archive
    Last Post: 06-18-2008, 01:37 PM
  4. 1974 century w440 getting hotter on one side
    By century19 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 10-05-2006, 08:27 AM
  5. 1972 115hp JohnsonProp feels resistance when in nuetral
    By eric_in_ks in forum Johnson Evinrude Outboard Archive
    Last Post: 09-08-2006, 10:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
