I have posted a thread on my 1982 Mercury Engine but need a cold starting tip on this engine. Jeff has helped my out a bunch. Only issue I have now is cold starting. I have replaced everything from fuel tank to rebuilt carbs pre service manual, new jets and floats,fuel pump, filter, fuel lines, spark plugs. 140 psi on all cylinders within a pound or two. Since engine has a enrichment valve this is new to me. My first Mercury. The major problem I found with engine was the fuel pump had a hole in it. Now to cold starting. I have been to lake three times and choking engine will not start. I have to spray a little starting fuel in it to start. I am carrying a spray bottle on boat with mixed fuel with me. I know the carbs are clean and they are getting fuel. Primmer bulb tight. Pulled top main jet and bowl had fuel. I am doing something wrong. Push center knob to fast idle and push key in for choke. Chokes enrichment valves are turning with key pushed in or manual knob pulled. Engine runs great after starting first time the rest of the day. So what am I doing wrong?
Thanks, Andy
Thanks, Andy
