This weekend on the way back in my boat 2006 246 Chaparal w/ 350 MAG Mpi wont go back on plane after coming off to tend to a sleeping kid on board. I gave it gas to go back on plane but the engine wasn't giving enough to get back up (i'm not sure what RPM or speed). I went back into neutral and opened the engine compartment to see water coming in. While it seemed like a treamendous amount at the time, after calming down and looking at where the high water mark left a line, it seems like it was about 6 inches or so. The water leaked only when the engine was running and quickly was pumped out and stayed dry the rest of the way home while under tow. When i got towed back to my dock, I fired her up and found the source of the leak which was a broken clamp on the hose coming out of my water pump, as it went into a 3 way diverter.
I've replaced the clamp and washed the engine down with fresh water to get as much salt out as possible. It's now dried out for a few days, but it looks like some water got into the engine oil, as when i checked the dipstick, I could see droplets on the length of the stick. I would like to suction out the oil but wasn't sure what the best procedure would be to get most, if not all, of the oil out. Should I run the engine for a short time just prior to extracting the oil? Or is there something that can be put into the oil to help rid it of water? I don't believe that the oil level was effected significantly, so i don't think there is a lot of water.
Finally, what else should i look at prior to starting her up and what do i look for once she is running?
Thanks,
John
Thanks,
John
