Click for Hino manuals!
Results 1 to 4 of 4
  1. #1
    Join Date
    Dec 2006
    Location
    Nanaimo, B.C., Canada
    Posts
    1
    Default "Both Hino Engines (150 hP
    "Both Hino Engines (150 hP) have a Hino angle gear set driving a Bayliner adapter and rev sensor. Many times after 150 op hours either of the sensors show oil leaks, become erratic, then fail. After dissasembling the angle drive, the secondary shaft has a screw thread pumping section, to force oil. This appears to be pushing oil back towards the camshaft oil galleries. An oil seal (polymer o ring style) is mounted outboard of this but soes not contact anything. Downstream of this is the plastic drive shaft and Mecury style sensor which leaks.
    Can anyone please provide a name or number to identify these original Hino parts, or others, intended to seal oil? This drive is very well constucted, and leads one to think parts are missing. Who has a oilleak and sensor failure problem here?
    thanks commdrrod"
  2. #2
    Join Date
    Jun 2006
    Location
    Everett, WA, USA
    Posts
    14
    Default it is a dk3 faria tach sender
    it is a dk3 faria tach sender kit i have lots in stock. thanks keith blueridgemarine.com 1-800-621-2215
  3. #3
    Join Date
    May 2007
    Location
    ATHENS GREECE
    Posts
    2
    Default I WOULD LIKE TO KNOW IF I CAN
    I WOULD LIKE TO KNOW IF I CAN BUY SPARES OF A HINO MARINE W04 150 HP DRIVING A BAYLINER 3288 IN EUROPE SPECIALY IN GREECE OR ITALY.IS ENY POSSIBLE SERVICE AT THAT AREA ? ENY INFORMATION WILL BE APPRECIATED .
  4. #4
    Bill Romberger's Avatar
    Bill Romberger Guest
    Default I am purchasing a Bayliner 438
    I am purchasing a Bayliner 4387 w/ twin 250 hp Hinos....what can I expect..they have 1045 hrs each
Similar Threads
  1. Hino
    By bayliner3270 in forum Hino
    Last Post: 12-01-2014, 07:49 PM
  2. Replies: 7
    Last Post: 02-03-2011, 03:51 AM
  3. Information on Hino W06DTA
    By striker01 in forum Hino
    Last Post: 04-26-2009, 05:35 AM
  4. Replies: 2
    Last Post: 01-13-2006, 09:59 AM
  5. Looking for Hino Diesel
    By m in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 12-23-2001, 12:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
