I have a 2004 Mercury 25hp , 2 stroke tiller electric start that I bought new in 2005 . I was told to run the fuel mix 2x the fuel/oil ratio*for the first tank of 5 gallons for break -in . I did about 8 gallons to make sure . Now as I was using the engine it just didn't seem to be making full power*for a*25hp engine .* I got hurt and didn't use the engine but a few times over the next*5 years BUT did run the engine now and then with water hooked up to the lower unit to keep everything in good condition .
Well this year I got the engine ready with NEW Quick Silver oil , FRESH fuel and took the boat to the local lake to fish . Well it starts up just fine , idles fine and is good for about 50% throttle even though the throttle is open 100% .* One time the engine did run very nicely and the boat was very fast !* I was very happy that the engine was running very good finally !** That was the one and only time that ever happened or ran that good .*So I called up 2 seperate Mercury dealers and both told me it's "fuel delivery problems ". So*I told them I installed 2 new spark plugs , cleaned the fuel filter , bought new oil and fuel , I also cleaned the fuel tank out and also cleaned the fuel filter in the tank . I also replaced the bulb that you squeese to get the fuel up to the engine and checked the fuel lines and all was new and clean !*
So I asked them what the problem should be ?** They both told me I had a bad fuel pump probably from sitting . So I bought a new carb kit from*the dealer and rebuilt the carb .* This was my first carb rebuild on an outboard*BUT I*have been rebuilding auto carbs and engines for a very long time . So I am not*a total blank when it comes to engines .
So after the rebuild and making sure everything was very clean and nothing was clogged in the carb anyplace , I*put everything back together and pumped the new fuel and oil mix into the freshly rebuildt carb . It started right up and sounded just fine . So off to the lake for a test run . Well the same thing happened . It's good for about 50% throttle even though the throttle is open 100%*and I*can't get anymore RPM's out of the carb* no matter what I did !
Now this is a basically a NEW engine with maybe 25 to 30 gallons of fuel through the engine . It also has only run 100% for about*5 mins one day until the engine would cut out . Then I would put into nuetral and hit the starter button . It would start right back up with no effort at all . Then off I would go until about 30 sec. , then the engine would stop again . This went on for about*15 mins until it wouldn't start and run anymore . I used my electric motor to make it back to the docks .
Like I said , the engine never really ran 100% from new but that was my engine for the local lakes . I thought it would run better once the engine was broke in really well !* I had a 40hp I used most of the time on the river and*other lakes*. I since sold the big engine 2 years ago and just went to use just the Merc. 25* engine since it was basically new .
I have looked all over the internet and tried about everything to get the engine to run a full 100% but can't figure out what is wrong with the engine . I do know that the carb is fine since I have taken it off 3 times and checked everything to make sure I did it the correct way .* Even the gaskets looked fine to me BUT I did replace them with the NEW kit anyway !
I did read someplace about the "Reeds" and getting racing reeds . What exactally do the reeds do and could these be the problem ???
I*really hope someone has an idea since I can't afford the cost of the boat dealer plus wait 2 to 3 weeks before they can even look the engine over .
Sorry for the very long post but I wanted to make sure that I covered everything that is going on with the engine since I bought it new and everything I have checked and replaced so far !
It's very upsetting since the engine is basically new and only has maybe 4 (5 gal.) tanks run through the engine so far !* Being on disability really sucks with no extra money and now an engine that won't run right .
Thanks ahead of time for everyones help with my engine problems !**
Jim
Jim
