Results 1 to 3 of 3
  1. #1
    Join Date
    Jun 2012
    Location
    Pine Valley, NY
    Posts
    39
    Default How do you adjust throttle cable?
    There is alot of slop in my throttle, how do you adjust the cable to fix this?
    J. Brown
  2. #2
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    990
    Default Re: How do you adjust throttle cable?
    Do you have a single or twin levers, that is, one for gear and one for gas? In any case the gas lever should be all the way back. At the engine, check the cable has 1-2mm slack with carb all the way closed (idle). You may have an adjusting barrel, a clevis, or some other screwed on terminal which should allow you to remove the slack. If that doesn't cure it it may be something inside the shifter. These things are a nightmare to disassemble if its a single lever.
    Practicing the ancient art of ren-ching
  3. #3
    Join Date
    Jun 2012
    Location
    Pine Valley, NY
    Posts
    39
    It is a single lever. Back by the carb there is what looks like a big round, black plastic thing that looks like it may be turned one way or the other...I just don't know what it is!...I have tried to turn it but it doesn't budge easily either way...afraid of breaking something! I will take a pic of the assembly and post it on here, maybe then someone can tell me what I am looking at.
    J. Brown
Similar Threads
  1. Adjust throttle / idle on 1992 Johnson 150
    By fishhuntguy in forum Johnson Evinrude Outboard Forum
    Last Post: 08-18-2011, 12:00 AM
  2. Throttle cable ?
    By 88 thundercraft in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-08-2010, 11:47 AM
  3. Throttle adjust so it can go WOT 2001 50 hp
    By ttreewalkerr in forum Mercury Mariner Outboard Forum
    Last Post: 07-11-2010, 06:57 PM
  4. Properly adjust throttle and shift cables on a mercury 850
    By tomboni in forum Mercury Mariner Outboard Archive
    Last Post: 09-26-2007, 06:58 PM
  5. Where can I get a Throttle Cable
    By wlatour in forum Volvo Penta Gas Archive
    Last Post: 07-07-2007, 09:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
