I have a shot '64 Ford 221 with Eaton outdrive. Cost of rebuilding motor is prohibitive. Would like to pull entire unit and replace with Mercruiser 305 and outdrive. What problems can I expect to run into?
Thanks.
Bob
Bob, first off.... and depending on year model....., some Eaton out drives are nothing more than a Volvo Penta drive.I have a shot '64 Ford 221 with Eaton outdrive. Cost of rebuilding motor is prohibitive. Would like to pull entire unit and replace with Mercruiser 305 and outdrive. What problems can I expect to run into?
The 5.8L Ford (351) intake manifold is actually wider than the 5.0L.Just for general info, the 221,260,289 and 302 fords all shared the same basic block, just stroke and bore increases. The 351 windsor was also the same block but with larger heads and a narrower intake.
If it's an actual Eaton drive, I'd consider replacing it.
You'd be hard pressed to find parts for one today.
Would this outdrive stand up to the larger engines?
What, if anything, would fit with the least problems?
Thanks for your warning.
Bob, I don't recall if you have identified the drive as being Eaton or an Eaton tagged Volvo Penta.Other ideas are mounting standard rotation motor facing backward and driving off the front of the crankshaft or installing standard motor and using a different prop with the pitch reversed. Attempted to attach pix w/o success. Any ideas welcome.
Bob, I'd cut my losses, and pick up a donor boat, or pick up the parts needed to install a more conventional set up.Finding a useable 221 isn't that hard. It's the reverse rotation that's the problem. Is there any way to use some standard rotation motor with the existing outdrive?
1..... True!1..... Read in another thread that Volvo Penta never made a reverse rotation engine.
My setup is a Ford 221 ci and outdrive both marked Interceptor. The manual I got with the boat indicated the power unit was Volvo Penta.
2..... What do I really have?
Bob
Run.............. and as fast as you can!Have decided to scrape the existing setup as not worth the trouble. Have a lead on a running OMC outdrive w/electric shift from a doner boat. Two questions. 1. Will the transom cutout size/shape present a problem and 2. what should I be looking for regarding the OMC unit.
Bob
An AQ series drive....... perhaps 250 or later.What, if anything, would fit with the least problems?
