First....... if the RH Reverse Rotation engine is set up correctly, the Harmonic balancer and/or timing tab will be correct for Igntion timing in the oposite direction.When using a timing light with advance adjustment, do have to compensate for the direction of engine rotation?
As far as the light is concerned, 5 TDC is 5 TDC, regardless of direction of rotation. Is this correct?
-JJ
1.... JJ, that's about all you can do.I could do that. I could plot out the data in Microsoft Excel and generate a curve.
1..... What do I need to do other than base timing?
2.... Just vary the RPM and measure the angle at ignition?
