"As Mort states, if the ohm re
"As Mort states, if the ohm reading is okay, the new stator is most likely okay. The engine must be cranking over at least 300 rpms in order to energize the ignition.
Test after having enerything hooked up properly by.... removing the spark plugs. Rig up a tester whereas you can set a 7/16" gap. Disconnect the large RED electrical plug at the engine.
Crank the engine by using a small jumper wire from the battery terminal of the starter solenoid to the 3/8" nut onthe solenoid that energizes the solenoid (not the 3/8" ground nut).
Keeping in mind that the engine must turn over rather fast (300 rpms), you should have spark. Do you?
Spark Tester - Home Made
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4"
