Carborater rebuilt on a 2003 15hp. 4stroke
Don't got specs but wanted to say when removing and cleaning the tiny ports and passages in these carbs it can get kinda tricky every little hole spray cleaner thru and find the other end is spraying cleanly I also use compressed air after carb cleaner I've used welding tip cleaner to get into corroded spots ( be careful welding tip cleaner is abrasive so no in out sawing will open up portways and chane how she runs)
Rebuild is remember how u took it apart and put it back usually only 1 spring may fly out at you in the accelerator pump
