jerold
I have already replaced the water pump "plate" with the newer style shift rod seal. So it doesn't leak there. Where would be the next likely leak spot?
Also, the vent, fill, and drain screws.......One had a plastic washer, One had remains of the washer, and the other had no washer at all. Do you think a couple of those could be the culprit? Only about 3 hours run time since I changed the oil.....and the oil looks like this...........
Is there a way to flush out the unit, other than fill it with oil and drain it...?
