1992 bravo one mercruiser. Manual says to torque 6 to 10 lbs of load rolling torque, then make sure it still turns. Doesn't seem to be enough torque, even with a new lock nut. When the gimbal bearing has 100 lbs of torque on that gear. The last lock nut holding the gear on the drive shaft of the ujoint or yoke nut. Upper part of outdrive. Thanks in advance.
