i have a 2000 NSF5A 5hp 4stroke, when it hits full throttle it seems asif the engine is hitting a rev limiter but runs very rough(motor bounces around).
it does this while in gear or in neutral, if you back off the throttle just a bit approx. 1/8th turn it runs perfectly. i have cleaned the carb/ adjusted the float, changed spark plug.
what should i be checking for and or replacing.
thanks luke
thanks luke
