Volvo problems
A
ashleyfuqua
Guest
I have a 1994 3.0 gl that will
I have a 1994 3.0 gl that will not idle at low speeds. I have been told that it could be a possible exhaust manifold letting a little water on the piston causing it to miss. This problem goes away when the boat is running at increased rpm. Compression test was sat. I am getting fire on all cylinders. Any help would be greatly appreciated.
"I have an AQ 125A which is an
"I have an AQ 125A which is an older motor but is still a four cylinder, I would get a miss at high speed mixed with a little backfire through the carb. A little water would get in to the cylinder, also my head had began to deteriorate. At low speed it ran great. Sounds as though you may have a carb. problem."
that sounds just like what min
that sounds just like what mine did... i think i would try the exhaust manifold first. If it is not that it may be time for a valve job
