I am ready to replace all manifolds, elbows, and risers on my 440's. I know that I have previously read some tips from folks on the forum. Went through the archives and just can't find them. Some I believe were about the type of make of the gaskets and another I believe was mentioned by Jeff about sealing the stainless sleeve. Any suggestions would be appreciated.
Those M440 manifolds are mighty heavy, be careful. If you plan to replace risers, get old ones out of there first to lighten up manifold, otherwise if its just a gasket change leave as assembly and get some strong help to lift it out.
A day or so before you start, do this; Take one of the manifold bolts out and match it up with 2 new ones that you'll purchase from Fastenal, or McMaster-Carr (I believe 7/16-14 x measure length).
Now take your new bolts and cut the hex-heads off with hack saw, in vice. Now use hack saw to cut a screw-driver slot into bolt where head was.
Begin manifold job:
Drain and disconnect hoses, get all extra crap out of the way, these boys are, did I say heavy?, really HEAVY.
Remove second and second to last bolts on one manifold and replace them with pilot-bolts that you just made. Remove the rest of the bolts from that manifold and draw manifold away from cylinder head.
For installation, reverse procedure making sure that you apply silicone pipe-dope to bolt threads (bolt passes into cooling passage of cylinder head and will leak without pipe-dope).
For bolts where pilots are, get out your stubby screw-driver and remove pilot-bolts, replace with correct bolts.
The pilot bolts help prevent manifold from dropping onto a spark plug, or damaging fittings on oil hoses.
Good luck, and eat your Wheaties!
,Noel.
