nissansundancer
hello all, i recently troubleshoot my NS90A Nissan 90 hp and think i have narrowed it down to the cd unit. I have good compression but no spark at the plugs. I was told my recifier was bad and if i replace it that will fix the problem.....not.....the rectifier has nothing to do with ignition! I am convinced my rectifier is bad since i reversed polarity at my battery by mistake but my engine should still start. So....I narrowed my problem down to the fuse, ignition switch, exciter coil, ignition coil and cd being the main problems. I did a voltage check coming out of the exciter while cranking and got 105v dva. So...i know i got juice going into my cd unit but am getting nothing on any leads coming out going into my ignition coils thus producing spark at the plugs. problem is the cd unit right??? any thoughts?
