I have a 2002 Mercruiser 5.0L MPI Engine
Ser# OM351757
It starts and idles great. Problem is it cuts out for no apparent reason. Like someone turned key off. Put it in neutral and it immediately starts up with no hesitation and out of the hole no problem. Very random shut off. It will sometimes do it everry couple minutes and sometimes be good for an hour.
I have taken it in twice to dealer with no results. Unable to get it to do this in shop. There are no engine fault codes recorded.
We have changed fuel pump, filter with same results.
I have cleaned battery connectioins and wiggle tested all the wire harneses. Checked kill switch.
Like I said, it starts immediately and takes off like nothing happened, no audible alarms.
Tested battery voltage and it is 14.48Volts while running so that seems fine.
Any help would be appreciated, I think my next step is to change the ECM or maybe the IAC valve?????
Guys have said on other forums that the ECM on this engine is known to be faulty????
Just want to check every thing possible before I drop the big bucks on the ECM that is not refundable.
Ser# OM351757
