Reel Magic
1978 Johnson 85ETLR78C 85hp Outboard Motor - Fuel Leaking from Air Box Drain Hose
I need some help figuring out why I have fuel leaking from my air box drain hose into the air box from the crank case. It only leaks when the motor is in the higher rpm range from 3000-5000. It does not leak at idle or even when its below 3000 rpm. The motor currently runs perfect, starts right away, idles fine and runs wide open great. So why is the fuel coming into the air box? I recently replaced the air box gasket, but there is just to much fuel to keep it from leaking down and into the water. I have done no other repairs since it started leaking except take off the upper carb to reattach the fuel line that was leaking at that carb. I have ran the boat with the air box cover off and it doesn't appear excess fuel is coming from the carbs so I doubt the floats are to high but I could be wrong. I talked to a boat mechanic and he has never seen fuel come out of the air box drain and frankly it did make sense to him why it would run perfect if the crank case is being flooded with fuel?
Any help or help to get me in the right direction would be appreciated.
