"Thanks to Troy & Guy.
Question: So, pour into all six, correct? I was concerned that maybe a couple of the hoses were not necessary, in that it would just drain staright out onto the driveway. But, it seems like that pouring into all 6 will ensure all necessary cavities are filled and that if any does indeed drain onto the driveway, that denotes that all is filled and is as should be. Correct?
Is there any kind of schematic, avaiable on line, for the cooling system which shows the water flow from intake to
expulsion?
Last question (for now, while I have everyones attention)- Water exits the engine via the top left and right of the outdrive and exhaust exits through the prop hub - correct?
Thanks Again."
