Results 1 to 5 of 5
  1. #1
    Default 35hp Johnson timing
    Could someone tell me how to adjust the timing on a 1980s Johnson?
    Thanks, I'd sure appreciate it.
    Pipemaster17
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,888
    Default Re: 35hp Johnson timing
    The timing on your motor is " fixed " at the factory and should not need adjusting for the life of the motor.-----------If you are having issues with the motor then post them .-------Someone will be able to point you in the right direction on how to trouble shoot.
  3. #3
    Thank you. My 35 horse Johnson is missing about 800 to 1000 rpms on top end. I just had the carb rebuilt and and it made no difference. It runs ruff on the idle also. It's fresh gas cause I've run a few tanks through it this spring.
    Pipemaster17
  4. #4
    Thank you I'll take it off the lake Wed. and check those things.
  5. #5
    I couldn't pull my boat out of the water 'til now to check it. It still isn't running right. I have 125# psi in each in cyl. I have at least 1/2" spark on new plugs. Carb has been rebuilt. I checked all my grounds. HELP!
    Pipemaster17
Similar Threads
  1. parts interchangability 1958 35hp -1959 35hp
    By [email protected] in forum Johnson Evinrude Outboard Forum
    Last Post: 08-15-2017, 12:56 PM
  2. 84b 35hp Johnson
    By boatmadmaniac in forum Johnson Evinrude Outboard Archive
    Last Post: 03-04-2009, 05:33 AM
  3. Johnson 35hp
    By garryuk in forum Johnson Evinrude Outboard Archive
    Last Post: 10-01-2007, 04:57 PM
  4. Help find timing on flywheel 1967 35HP Mecury
    By mark in forum Archive 2003-2009
    Last Post: 03-30-2004, 04:39 PM
  5. Johnson 35hp ID
    By don in forum Outboard motors archive 2000-2004
    Last Post: 09-16-2002, 04:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
