Results 1 to 7 of 7
  1. #1
    Default crank shaft movement on a 3126
    Need help am rebuilding a 3126 marine uunit. I need to know the permisable fore and aft movement on the crank shaft so far im good but the movement seams just to much im in the boondocks in saudi and any help would be appreciated
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default Re: crank shaft movement on a 3126
    Crankshaft end play 3114 Engine ... 0.07 to 0.29 mm (0.0028 to 0.0114 inch) 3116 and 3126 Engines ... 0.07 to 0.32 mm (0.0028 to 0.0126 inch)
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  3. #3
    Quote Originally Posted by hystat View Post
    I thank you so much for that, yes sure the factory manual is the best i did manage to purchase a PDF OF THE MANUAL FROM THE STATES BUT ONFORTUNATLEY THE SITE WAS BLOCKED FROM THE SAUDI GOV, AND JUST YESTERDAY WE MANAGED TO RE-ROUT THE DOCUMENT THRU ANOTHER SITE I NOW HAVE IT, I would beg your assistance one more time sir i have a reading for the final cylinder head tourque settings for the large bolts 130_+ 15N.m then add 90 deg is that correct, this is the 3126 2000 model marine application.
    thanks for your help it is more than appreciated.
    regards
    Eric
  4. #4
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    I picked one of several 3126 marine serial number prefixes at random - might be different specs for each
    Use the following procedure to install bolts (1) and (2) :
    1. Apply engine oil to the threads of the bolts.
    1. Tighten large bolts (1) in a numerical sequence.Tighten the bolts to the following torque. ... 300 15 Nm (221 11 lb ft)
    1. Loosen large bolts (1) in a numerical sequence.
    1. Tighten large bolts (1) in a numerical sequence.Tighten the bolts to the following torque. ... 130 15 Nm (96 11 lb ft)
    1. Tighten the large bolts (1) again in a numerical sequence.Tighten the bolts to the following torque. ... 130 15 Nm (96 11 lb ft)
    1. Turn large bolts (1) in a numerical sequence an additional 90 degrees (1/4 of a turn).
    1. Tighten the small bolts (2) in a numerical sequence.Tighten the bolts to the following torque. ... 55 7 Nm (41 5 lb ft)
  5. #5
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    I'm not sure how you are planning to set up the injector synchronization and fuel setting. There's a lot of specialized tooling required- and hands on training imo. Maybe there's a dealer in that region that works on 3116 mui Cats in trucks - they will have the tooling.
  6. #6
    aaaaa
  7. #7
    Dear sir
    it is much appreciated we are 5 Filipino and one Brit we have a Isusu Mechanic with a instrument to check angle , i have a DTI TO CHECK THE CRANKSHAFT MOVEMENT AND I AM MOST HAPPY TO SAY WE HAVE YOU ON THIS FORUM WE SHALL KEEP YOU INFORMED, WE HAVE DONE THE CYLINDER HEAD VALVES SPRINGS ETC, CRANKSHAFT ORIGINAL, CONNECTING RODS ORIGINAL CROWN AND SKIRT NEW LINERS FITTED AND HONED ALL BEARINGS AND SEALS NEW , TO GET THOSE PARTS TOOK 28 DAYS, WE ARE 90% COMPLETE WE SHALL PUT IT BACK IN THE BOAT TODAY AND CRANK IT, WE SHALL SURELY LET YOU KNOW, THE LAST ONE RE-BUILT BY A eGYPTIAN mASTER mECHANIC RAN FOR 4 HOURS UNDER LOAD THEN WE NOTICED IT STOPPED AND THERE WAS A LARGE HOLE IN THE ENGINNE BLOCK.
    BEST REGARDS sIR
    eRIC
Similar Threads
  1. Crank shaft splines
    By scruffy63 in forum Johnson Evinrude Outboard Forum
    Last Post: 12-10-2011, 06:59 PM
  2. Crank shaft
    By sidebottom in forum Johnson Evinrude Outboard Archive
    Last Post: 06-13-2008, 02:17 PM
  3. Outboard crank shaft rebuild
    By sherman in forum Archive 2003-2009
    Last Post: 05-22-2003, 12:54 PM
  4. Stainless steel crank shaft
    By Dan Stephens in forum Archive 2002-2006
    Last Post: 08-14-2002, 05:33 PM
  5. Merc V6 Crank Shaft Repair
    By Hal Watts in forum Outboard motors archive 2000-2004
    Last Post: 03-13-2002, 03:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
