Capt Dave
Looking for a Male plug*which plugs into the 1989 Mercruiser engine harness(female*socket) which is attached to*a bracket mounted to the starboard side exhaust riser.* The actual harness socket has 9*pin holes and is made by "medallion" w/ a Mercruiser part:** *# 84-96020-A 4'*(4', but have seen some showing 6').
The problem is that the two plugs don't fit together well & appear to have heated up over the years and the male plug is slightly distorted.* Have put together and clamped w/hose clamp which works well for awhile and then stops ALL POWER FROM GETTING TO THE BOATS DASH BOARD:**I HAVE* NO POWER FOR THE ELECTRIC ENGINE HATCH AND THE ENGINE START KEY IS DEAD AS WELL AS ALL GAUGES, TRIM TABS ETC.........IF THIS WOULD OCCUR WHILE RUNNING LAKE MICHIGAN OR THE MISSISSIPPI IT COULD GET REAL UGLY.
ANY IDEAS?
THANKS* CAPT DAVE
ANY IDEAS?
THANKS* CAPT DAVE
