MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Default Merc 115Hp will turn over but not start. Help!
    I have a 1993 Mercury 115 HP, 4 Cyl, 2 stroke. Went to the lake the other day, unloaded it, started it up, boated to fishing spot, fished for an hour, went to move to another spot. Boat wouldn't start! Motor turns over easily, but won't start. Check for fuel, got it. Check for Spark, don't got it. Check the kill switch, it's good and in place. Where do I look next??????
  2. #2
    Default Re: Merc 115Hp will turn over but not start. Help!
    Your going to have to get yourself a wiring diagram. Possible causes, bad ignition module, bad coil, poor ignition wires or bad ignition trigger. Do you have an multimeter and now how to use it?
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    11,983
    It can be difficult to check for spark in broad daylight.----------Try again in the evening or out of the sun with a proper spark checker.
  4. #4
    Yes I have a multimeter and know how to use it. I think the wiring diagram is on the bottom side of the deck lid. I have looked for broken wires, loose connections. I have even replaced ignition module. Still nothing. I just don't know what to check for with the meter.
    I will check for spark with a spark checker tonight.
  5. #5
    If the resut is no spark you can test the ignition trigger at the modue connector. will prodce an AC voltage while cranking. Test the primary wires on the coils using a test light One will have power and the other will fash when the engine is cranked. Report back.
  6. #6
    Quote Originally Posted by Ruggybuggy View Post
    Hey Ruggybuggy,
    I notice my starter drive stays engaged in the flywheel, even with the key off. It's loose, but it won't come down away from the flywheel. Does this mean anything?
  7. #7
    Join Date
    May 2012
    Location
    Maui
    Posts
    114
    Stator, trigger or switch box will leave no spark on all cyl. coil plugs and wire don't all go out at same time
Similar Threads
  1. 454 Crusader will turn over but not start
    By skimmer27 in forum Crusader Marine Archive
    Last Post: 08-30-2008, 07:53 AM
  2. Merc 175 no start Turn over no fire
    By eric_scott in forum Mercury Mariner Outboard Archive
    Last Post: 08-16-2008, 11:49 PM
  3. Replies: 0
    Last Post: 08-12-2007, 07:27 AM
  4. 05 30 cruiser Turn Key Start
    By doug_k in forum Mercruiser Sterndrive Archive
    Last Post: 03-05-2007, 07:05 PM
  5. 1976 115hp Evinrude wonbt turn offWiring diagrams
    By Michael Heffey from Australia. in forum Outboard motors archive 2000-2004
    Last Post: 02-13-2001, 04:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
