gulfcoastsurf
I have a 1998 Honda bf 90 that has been running pretty good, today after cleaning the boat and checking the oil with the cowling off, I started pumping the fuel bulb and there was a small spray on the boat side fuel line that comes off of the "T" connector before the lower fuel pump. The next day I crank her up and while she was running no spray, no fuel leak, but when i pump the bulb until its maximum its spray again shortly and stops as soon as I let go of the fuel primer. Should I change the hose going to the fuel pump or is that acceptable seeing how it does not leak while running when the bulb is not excessively primed?
