Front seal around the crank shaft on the timing chain cover leaking. 350 Crusaders. When I first posted this a few months back I thought I would need to pull the timing chain cover. Since then a guy at my marina and the parts guy at the marina chandlery told me this is not necessary. Remove the harmonic balancer carefully pry out the old seal then put some oil on the rubber seal or the crank shaft slide it on and evenly tap it in till it seats. Its been a long time for me since I built my last small block Chevy. Is this correct??
Jim
Early small block 1969-70 vintage.
Jim
