Results 1 to 2 of 2
  1. #1
    Default How to set timing on 1989 90hp Evinrude
    Is itpossible to set the timing on my 1989 90hp “E90TLCEM” while in the driveway? Iknow to hook up water and I have a manual and familiar with timing a car.
    Themanual ‘reads” it must be in gear @ WOT to set the timing. It states to takeoff the propeller, etc but I just wanted some input from others who have experienceto shed some light on the process.
    Thankyou,
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    13,494
    Default Re: How to set timing on 1989 90hp Evinrude
    (Timing At Cranking Speed 4°)
    (J. Reeves)
    NOTE: If your engine has the "Fast Start" feature", you must disconnect/eliminate that feature in order to use the following method. The "Fast Start" automatically advances the spark electronically when the engine first starts, dropping it to normal when the engine reaches a certain temperture.
    The full spark advance can be adjusted at cranking speed,"without" have the engine running as follows.
    To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
    Rig up a spark tester on the #1 cylinder plug wire. Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
    It's a good idea to ground the other plug wires to avoid sparks that could ignite fuel that may shoot out of the plug holes. I've personally never grounded them out and have never encountered a problem (fire) but it could happen.
    I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°.
    If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
    No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
    Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
    http://shop.ebay.com/Joe_OMC32/m.htm..._sop=12&_rdc=1
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
Similar Threads
  1. Eratic timing marks at idle with timing light. 1989 2.3 L
    By NewBoatGuyGeorge in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-23-2010, 12:39 PM
  2. 90hp V4 Timing wheel
    By jase in forum Johnson Evinrude Outboard Archive
    Last Post: 10-06-2008, 04:50 AM
  3. 1989 200 Evinrude timing
    By drx in forum Johnson Evinrude Outboard Archive
    Last Post: 06-01-2007, 07:40 PM
  4. 1989 90hp Evinrude loss of power
    By kermit in forum Johnson Evinrude Outboard Archive
    Last Post: 10-01-2006, 12:14 AM
  5. 1989 90hp Evinrude Fuel Consumption
    Last Post: 06-14-2006, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
