Results 1 to 4 of 4
  1. #1
    Default Whats the advantage?
    I was wandering what is the advantage/disadvantage on mounting the axle above or below the trailer springs. Originally it was mounted to the bottom and almost all trailers that ive seen so far are mounted on top. I understand that their is ground clearance difference but what else? Which way should I go back with it?
  2. #2
    Default Re: Whats the advantage?
    What make of trailer is it ?. It really doesn't matter on some trailers.
  3. #3
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,971
    Primarily it's a ground clearance issue, especially with small trailors with small tires. Also, if the bunks or rollers sit lower, it is easier to load the boat on shallower ramps.
    CHawk 25 DLX
  4. #4
    OK its a 1969 Dilly trailer I think and it has 4.8 X 12" tires so im assuming just keep it the way it is because if im not mistaken if I put it on top it will make the trailer sit lower and well its pretty low as it is.
Similar Threads
  1. Is there an advantage from switching to a stailess propeller
    By bobsea in forum Propeller Selection and Replacement
    Last Post: 12-30-2009, 04:50 PM
  2. Whats better 470 or a 165
    By pakula_sunrise in forum Mercruiser Sterndrive Archive
    Last Post: 05-15-2009, 05:20 PM
  3. Whats this
    By w. beasley in forum Archive 2003-2009
    Last Post: 12-09-2005, 07:28 AM
  4. Whats it mean when
    By Matt Winkler in forum Archive 2003-2009
    Last Post: 07-13-2003, 11:38 AM
  5. Whats the gap
    By Jay rodevitz in forum Outboard motors archive 2000-2004
    Last Post: 03-25-2003, 04:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
