MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Join Date
    Nov 2008
    Location
    Posts
    54
    Default 115 mercury swith box test
    Hello,
    I read on here a while back how to test a switch box on a 70's model mercury 115 can someone that knows how to do that repost it please I got one i need to check.
    Thanks for help.
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,782
    Default Re: 115 mercury swith box test
    The acceptable voltage range for battery type ignitions is typically 9.5 Volts (at cranking) to a maximum of 16 volts at full throttle
    (13.2-14.6 preferred). Voltages above or below this range can cause damage to the CD.
    DO NOT USE A MAINTAINENCE FREE, DRY CELL OR AGM BATTERY WITH ANY BATTERY DRIVEN CD UNIT!
    No Fire on Any Cylinder:
    1. Clean all battery connections and engine grounds.
    2. Disconnect the mercury tilt switch and retest. If the ignition works properly, replace the mercury switch.
    3. Connect a spark gap tester to the spark plug wires and check for fire on all cylinders. If some cylinders fire and not
    others, the problem is likely in the distributor cap, rotor button or spark plug wires. Notice: If the unit only fires when
    you let off of the key switch, the trigger is usually the problem.
    4. Check voltage present on the White wire at cranking. It MUST be at least 9 volts. If not, the problem is in the
    harness, key switch, starter or battery.
    5. Check voltage present on the Brown wire at cranking. It MUST be at least 9 volts. If not, the problem's likely in the
    pack.
    6. Check DVA voltage on the Green wire going to the coil. It should be approximately 200 volts at cranking.
    7. With the spark gap tester to the high tension lead coming from the ignition coil, disconnect the Brown, White and
    Black trigger wires. Connect a jumper wire from the slot for the Brown wire to the slot for the White wire. Connect
    another jumper to the slot for the Black wire and (with the key switch turned on) strike the jumper against engine
    ground. The unit should fire each time. If it does, the CD module is usually good.
Similar Threads
  1. test
    By Danebramage in forum Mercury Mariner Outboard Forum
    Last Post: 10-20-2010, 09:38 AM
  2. can i swith my aq 151 to a 171?
    By franklinfleagle in forum Volvo Penta Gas Engine Forum
    Last Post: 07-18-2010, 06:04 AM
  3. Small Outboards: Sea test Vs. Tank test
    By skiffscott in forum Johnson Evinrude Outboard Forum
    Last Post: 04-24-2010, 12:18 AM
  4. Tank Test or Muff Test
    By silkscreeners in forum Johnson Evinrude Outboard Archive
    Last Post: 04-30-2007, 03:42 PM
  5. Mercury voltage regulator test
    By barry in forum Mercury Mariner Outboard Archive
    Last Post: 04-08-2004, 08:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
