Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2012
    Location
    Clemson, SC
    Posts
    110
    Default OMC components to mercruiser components
    Ok guys, I'm about to transplant the 470 from donor boat to the winner. Will I need to move all controls and wiring over with it? Such as gauges key and receptacle... all that good stuff? I think the mercruiser is a yellow plug and the omc was black? I'll probably switch everything over but can I keep all the gauges that are already in the boat?
    I know I'm not giving much info but If you guys give me a heads up on what I need to look for I can do that.
    Thanks,
    Jas0n
  2. #2
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,414
    Default Re: OMC components to mercruiser components
    The key switch and guages are typically universal so they can stay.
    You just need to attach the correct colors to the correct locations based on mercs color code from the merc wire harness. You do need to swap the main wiring harness as the pinouts are most likely different.
    The shift controlls and cables are different. OMC and MERC are not the same. One is a push, push and the other is a push, pull control if I am not mistaken.
    No easy way, got to do it all.
  3. #3
    Join Date
    Mar 2012
    Location
    Clemson, SC
    Posts
    110
    Dang! Not the answer I was hoping for, but thanks! I wish I wasn't so pinched for money... I would have bought something nice to start with.
  4. #4
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,414
    If you can identify what wires go where then you could make it work BUT that is your choice and most likely you would need to cut and splice, Not reccommended but it is your project!!
    Any used boat with a merc does not have to be a 470, any motor wiring harness will work, just need the approximate year with in 2 or o so years, go find a dead boat that you might be able to strip down what you need..........the wiring harness and controls are the same for all motor combo's.....
Similar Threads
  1. engine swap 260 mercruiser to 228 mercruiser questions
    By jfowler502 in forum Mercruiser Sterndrive Forum
    Last Post: 05-21-2011, 08:23 AM
  2. can I replace outboard mercruiser 4.3 with a mercruiser 470?
    By boatforfun in forum Mercruiser Sterndrive Forum
    Last Post: 12-01-2010, 07:08 PM
  3. OMC Ford 302 EFI Components
    By marshall43 in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-13-2007, 07:44 AM
  4. Automotive ignition components on marine gasoline engines
    By el_pescador in forum Volvo Penta Gas Archive
    Last Post: 09-10-2007, 11:20 PM
  5. Mercruiser specs For a 1977 37 470 mercruiser
    By daveolejnik in forum Mercruiser Sterndrive Archive
    Last Post: 02-25-2007, 07:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
